Hiding an amp
simonj
69
Has anyone found a good place to hide an amp in the Leon, I need the full boot space and making a custum sub enclusure that fits in the spare wheel instead of the toolkit. Will one fit under the front seats?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Heat dissipation could be a problem with under the front seats as heat rising would rise straight into the seat base. Back of the back seats? Or if you pull back the carpet on the left of the boot side, you will find a polysterene block, remove this and you might have room to do something there?
cheshmatt
Cheers for that tip Danny - I've been thinking about mounting my amp on the left side somewhere, haven't got around to pulling the carpet off yet.
(sorry to hi-jack Simon)
simonj
69
not at all it all helps us, I will check the size but the amp I've got is huge.
don't fancy making a false floor as it will still take up some height of the boot and only the other day I had trouble fitting 2 suitcases in the boot taking the parents to the airport and have to do a few more runs this year.
Cupra_Tim
71
Pontypool (South Wales)
would this be hiddin enough?
