HID help :)
mazzerati
Bags are for groceries!
Jun 27, 2008
1,980
Beverley, East Yorkshire
i got some HIDs today for my single cluster headlights so they are H4's (hi/lo)
i put them in and they work fine, but the bulb comes with like a metal cover round it.
and ive noticed that there is like a metal deflector like thing inside the headlight.
do i need to remove either of these or just leave them in?
http://www.hids-direct.co.uk/hid-co...s/ultra-h43-hilo-beam-35w-hid-kits-p-260.html
picture two shows the metal surround
thanks
Neo
Fool member
Mar 24, 2009
881
Your link shows that they are H4-3 bulbs you have bought, so I believe you leave the metal cover on the bulb.
When you switch to high beam the metal cover is moved by a solenoid to change the beam to high.
Does it mention it in your instructions?
Neo
Fool member
Mar 24, 2009
881
Ah I see... You mean the diffuser? Circled in the pic (I know it`s a twin reflector and yours is single).
To be honest I`ve never fitted a Bi-xenon kit but I would imagine that the Bulbs you have are larger than standard to accomodate the integrated cover.
I would say the standard diffuser would`nt be needed anymore.
mazzerati
Jun 27, 2008
1,980
I managed to get the metal bit out just slid through the hole where the bulb goes gunna have to make a little bracket to hold te metal clip that holds the bulb in place!
Investigation ongoing ;)
ben-ducky
176
Llanelli, S Wales
i know this is off topic but what sidelights do you have? they look good. very white! thanks
