Hid Fitters???
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
are there actually any places that will fit HID's as im a complete numpty when it comes to anything modifying, also will they fit them with angel eyes, as i quite fancy HID'd ones...
thanks adam!:D
Jan 19, 2006
1,024
fife, scotland
i'm mechanically dyslexic and i managed mate. the hardest bit is drilling the black plastic covers and even that is a piece of piss, surely if you cant manage then someone on here will do it for nowt mate, if i wasn't so far away i would do it for you no probs. in total its probably a half hour job. don't go to a garage, they'll charge about 80 quid or something stupid.
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
Honestly mate it is SOOOOO easy! you dont need a walkthrough. Please dont pay someone to do a job as easy as this. If you can change one of your headlight bulbs then you CAN fit the HID's;)
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
ahh yes, i know wot you mean...im quite capable of changing the bulbs as iv done it a few times, trying to get the whitest bulbs i can, to match up to HID brightness but i think im just going to have to cut my loses and join the 6000k club haha! can anyone suggest a good set, link to it preferably?? thanks
STEFanGB
55
PaulLC
85
Tyne & Wear
Ive got angel eyes and just bought a 6000k HID kit, ive just been out and pluged them in to see what they are like, iam well impressed!!!! it took less than 1 minute to plug in, all thats left to do is take the lights out and make the holes slightly bigger for the HID bulbs to fit.
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
what do you mean slightly bigger Paul? Is a big job or just a few mm and how you planning on doing it? I like the look of the angel eyes and just want to know how to fit the HID kit if i decide to buy them. Cheers
But Spudisdabest as everyone else is saying ive got 6000k set on my standard lights and so so simple to fit.
Each wire will only plug into one port so cant go wrong. Just check the fuses if one doesnt come on when testing as the HID kit draws more current for a few seconds then normal bulbs when u turn them on.
Never want to drive a car with standard bulbs now and for £40 well well worth it.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
You normally just need a hole cutter - 25mm for standard lights but am not sure about angel eye fitments.
Phil K
Here's your sign
Oct 18, 2004
548
Surrey darling...
Is 6000K quite blue or does it look about the same as OEM HID's... I want to get some but really don't want it to look too blue like some of the after market kits you see!
lc_allan
Northern Monkey
Sep 15, 2006
3,389
6000K is more white with a small hint of blue, 8000k is the bluer one.
Search for a light chart to show the differences.
PaulLC
85
Tyne & Wear
I got the 6000k hids and when using them in a projector light they are blue but in a normal set of lights they just have a tint of blue.
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
That's because in normal HID OEM use, the HID lights are 4300K - it's the projector lenses that give the blue tint. In normal reflector lenses, you use a 6000K bulb to give the same look that 4300K gives in projectors. 6000K in projectors will give off a white light but with a stronger hint of purple around the edges.
