hi got 2005 ibiza tdi need front discs and pads just wondering can i go to a garage
andrewseattdi
hi there have a seat ibiza tdi 05 plate done 44k now needs new discs and pads front and rear been quote ££££'s from seat in peterborough was wondering if i get the parts and then find a garage to fit them for me question is will it still be under warrenty if i dont get them done with seat
need help also does any one recommend any good garages in around cambs area local to me downham market many thanks
norrie
200
Edinburgh
Nothing will affect your warranty if you fit genuine parts regardless of where they are fitted.
Not sure if you fit aftermarket parts.
I think as long as they cant prove that the parts that were fitted caused the problem you will be okay.
Norrie.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
you need to fit genuine SEAT parts by a VAT registered garage and your warranty will be 100% , its called block exemption , if you could get a receipt from the garage stipulating they used genuine parts and get the receipt for the parts , no one can argue
if you use a vag specialist, they'll keep you right , awesome gti , jbs autodesigns or star performance in scotland
gazjones
try jabba sport in peterborough they are vag specailists just use standard pads and disks for warrenty sake but bit more expensive than aftermarket ones
