Help with ordering Forge TIP for K03s
Prebs
662
Norway, Bergen
Hi. Im about to order the Forge TIP for my new A&M k03s (-00 cupra 1.8t)
Quote from Forge:
-Dear Sir
Thank for the e mail order
please can you confirm your engine code .
Please confirm you have Ibiza cupra mk3 1.8T ( not cupra R )
cheers
peter
Wich one will fit the k03s????
I thought there was only one of these for the ibiza mk3:confused: ???
Please help as my order is ready to go!
Prebs
flashbsd
AYP or AQX , same one :) , its made for the k03 but it slips over the k03s happily :)
flashbsd
dont know what theyre on about :rolleyes: , the cupra R has the same AYP engine just a different ECU :)
Prebs
662
Norway, Bergen
Thanks DAZ, I know about that coolant pipe as I had some small probs when I first fitted a bigger steel TIP (bougt one from a lad in slovenia, as seen in the fitting guide) Had to loosen the bolt that holds the coolent pipe on to the engine block and it was quite fidly to reack it with the wrenck so I ended up loosing the bolt somewhere in the engine bay and I never seen it again:) I even looked under the car with a infra red heat camera as the bolt was still warm but couldt find it. So I know the work of fitting the TIP:)
Prebs
flashbsd
i didnt cut mine though, it aint gonna move as the coolant pipe moves with the whole engine block also (so minimal rubbing can happen).
IMO if the standard TIP fitted the k03s, i would have kept it :)
