help with logs
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hey all,
Just did some logging, first time actually:funk:, i did all the logs in 3rd gear from about 1500 to 2000 rpm up to as close as i could to red line as i read from previous posts.
The problem is, i have not idea what they really mean:think:.Could someone out there that knows what they are talking about mind taking a quick look and letting me know if my car is running with in the correct parameters.The only thing i seen was the G/S on other car logs on here looks to be higher than mine.
My car is a 03 LCR 210HP with a drilled airbox(my bad) and a DV007p
Code:
Tuesday	20	November	2007	20:02:30
1ML 906 032    		1.8l R4/5VT         0001
	Group A:	'003				Group B:	'115
		RPM	Mass Flow	Load	Ign. Timing		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °ATDC	STAMP	 /min	%	 mbar	 mbar
	0.69	1360	22.78	62.7	13.5	0.01	1200	80.5	1360	1050
	1.9	1760	32.78	79.6	14.3	1.38	1560	88.7	1550	1130
	2.91	2120	47.61	87.5	12.8	2.4	1920	97.7	1620	1260
	4.13	2720	77.61	96.9	9	3.52	2400	126.3	1700	1550
	5.34	3400	92.97	100	17.3	4.72	3040	143.6	1670	1710
	6.6	4040	114.81	100	18.8	6.01	3720	145.1	1710	1700
	7.64	4640	130.5	100	17.3	7.14	4360	145.9	1730	1710
	8.75	5200	141.44	100	17.3	8.24	4920	149.6	1740	1700
	9.85	5720	160.56	100	19.5	9.25	5440	146.6	1770	1760
	10.99	5840	5.72	9.8	6	10.36	5920	148.1	1680	1740
	12.3	5640	12.94	9.8	6.8	11.65	5760	12	990	1080
	13.47	5440	13.44	9.8	6	12.88	5520	12	990	1040
	14.68	5200	12.56	9.4	6	14.09	5320	12.8	990	1020
	15.91	5040	12.36	9.4	6	15.28	5120	12.8	990	1020
	17.2	4880	11.97	9	5.3	16.57	4920	12.8	990	1010
	18.4	4680	11.22	9	4.5	17.8	4760	12.8	990	1010
	19.61	4480	11.69	8.6	3.8	19	4600	12.8	990	1000
	20.72	4320	11	8.6	3.8	20.2	4400	12.8	990	1000
	22	4160	10.83	8.2	3.8	21.33	4280	12.8	990	1010
	23.33	4000	10.03	7.8	3.8	22.72	4080	12.8	990	1010
	24.53	3840	9.83	7.5	3	23.94	3920	12.8	990	1020
	25.64	3720	9.42	7.5	3	25.05	3800	12.8	990	1020
	26.85	3600	10.75	8.2	1.5	26.26	3640	15.8	990	1020
	28.13	3440	9.08	7.5	2.3	27.55	3520	13.5	990	1020
Code:
Tuesday	20	November	2007	15:57:53
	Group A:	'032				Group B:	'020
		Lambda	Lambda	Bin. Bits	Bin. Bits		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	%	%			STAMP	 CF	 CF	 CF	 CF
	0.59	-0.4	-7.8	        	        	0.01	0	0	0	0
	1.82	-0.4	-7.8	        	        	1.22	0	0	0	0
	3.08	-0.4	-7.8	        	        	2.48	0	0	0	0
	4.22	-0.4	-7.8	        	        	3.62	0	0	3	0
	5.23	-0.4	-7.8	        	        	4.73	0	0	3	3
	6.35	-0.4	-7.8	        	        	5.76	0	3	2.3	3
	7.59	-0.4	-7	        	        	6.94	0	2.3	2.3	2.3
	8.86	-0.4	-7	        	        	8.25	3	2.3	1.5	1.5
	10.07	-0.4	-7	        	        	9.46	3	1.5	0.8	0.8
	11.28	-0.4	-7.8	        	        	10.67	0	0	0	0
	12.48	-0.4	-7.8	        	        	11.88	0	0	0	0
	13.74	-0.4	-7.8	        	        	13.15	0	0	0	0
	14.88	-0.4	-7.8	        	        	14.3	0	0	0	0
	16.1	-0.4	-7.8	        	        	15.5	0	0	0	0
Code:
Tuesday	20	November	2007	15:56:22
	Group A:	'031				Group B:	'118
		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME
MARKER	STAMP					STAMP	 /min	°C	%	 mbar
	0.01	0.867	0.953	        	        	0.59	1320	20	95.3	1120
	1.1	0.953	0.953	        	        	1.71	1600	18	95.3	1170
	2.37	0.961	0.953	        	        	2.97	1920	18	95.3	1280
	3.51	0.938	0.953	        	        	4.12	2360	18	78.8	1580
	4.73	0.961	0.953	        	        	5.33	2920	18	64.3	1720
	5.93	0.938	0.953	        	        	6.44	3440	18	64.3	1710
	6.94	0.969	0.953	        	        	7.5	3920	18	65.5	1750
	8.13	0.961	0.953	        	        	8.65	4440	18	66.3	1750
	9.26	0.969	0.953	        	        	9.86	4920	19	67.8	1760
	10.47	0.945	0.953	        	        	11.08	5440	20	70.2	1780
	11.66	0.938	0.953	        	        	12.17	5840	21	71	1790
	12.85	0.93	0.953	        	        	13.46	6200	22	0	1390
	13.99	0.984	0.961	        	        	14.58	4680	21	0	1060
	15.2	1.991	1.047	        	        	15.79	4520	22	0	1020
	16.39	1.991	1.047	        	        	16.99	4360	23	0	1020
	17.5	1.991	1.047	        	        	18.18	3640	23	0	1020
	18.77	1.991	1.047	        	        	19.31	2040	23	0	1010
Thanks in advance
Rob
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
is that on full trottle?
Try measuring these logs
003 + 020
115 + 031
118 + 032
Doing 2 at a time (for accuracy)
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hi,
Yes, full throttle from about 2000rpm to red line in 3rd gear, i can't log in 4th as i will be put off the road.
I got the logs below that you asked for.
Rob
Code:
	Group A:	'003				Group B:	'020				Group C:	 Not Running
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF	STAMP
	0.6	3200	7.92	6.7	12.8	0.01	0	0	0	0
	1.79	1840	17.81	11.8	19.5	1.21	0	0	0	0
	3.01	1800	29.5	21.2	20.3	2.48	0	0	0	0
	4.13	2200	54.14	89	13.5	3.51	0	0	0	0
	5.33	2800	78.36	98	12.8	4.74	0	0	3	0
	6.54	3480	97.67	100	16.5	5.94	0	0	2.3	3
	7.82	4120	118.44	100	21	7.13	0	3	2.3	3
	8.85	4680	130.69	100	17.3	8.35	0	2.3	1.5	2.3
	10.06	5240	152.94	100	18	9.46	0	2.3	0.8	2.3
	11.27	5760	162.72	100	15	10.67	0	1.5	0.8	1.5
	12.55	6240	166.61	100	16.5	11.88	0	0.8	0	0.8
	13.68	6280	9.5	10.2	21.8	13.16	0	0.8	0	0.8
	14.79	5800	13.89	10.2	7.5	14.2	0	0	0	0
	15.99	3680	9.14	7.1	3.8	15.4	0	0	0	0
	17.19	2080	5.42	4.7	3	16.59	0	0	0	0
	18.47	1160	3.28	3.1	3.8	17.85	0	0	0	0
	19.52	4200	10.67	8.2	20.3	19	0	0	0	0
	20.62	4040	10.11	7.8	3.8	20.11	0	0	0	0
	21.73	3840	9.94	7.5	3	21.22	0	0	0	0
	23	3480	9.22	7.1	2.3	22.33	0	0	0	0
Code:
	Group A:	'115				Group B:	'031				Group C:	 Not Running
		RPM	Load	Absolute Pres.	Absolute Pres.		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP					STAMP
	0.56	1800	82.7	1450	1050	0.01	0.883	1
	1.72	1320	88	1440	1140	1.17	0.938	1
	2.91	1600	94	1590	1210	2.3	0.961	0.953
	4.03	1960	104.5	1650	1340	3.42	0.961	0.953
	5.26	2440	139.1	1720	1700	4.63	0.938	0.953
	6.51	3040	147.4	1670	1710	5.87	0.938	0.953
	7.65	3600	143.6	1710	1700	7.05	0.953	0.953
	8.87	4120	145.1	1710	1720	8.25	0.969	0.953
	9.96	4600	145.1	1740	1740	9.45	0.953	0.953
	11.07	5080	149.6	1760	1750	10.46	0.945	0.953
	12.31	5600	151.1	1780	1760	11.74	0.945	0.953
	13.5	6080	153.4	1700	1720	12.89	0.938	0.953
	14.69	6440	136.8	1680	1710	14.09	0.938	0.953
	15.89	5120	14.3	1010	1130	15.31	0.906	1
	17.08	3560	12	1010	1060	16.4	0.906	0.953
	18.2	3120	12	1010	1040	17.62	1.991	1.047
	19.3	4120	12.8	1010	1050	18.71	1.991	1.047
	20.34	3800	12.8	1010	1050	19.81	1.991	1.047
Code:
	Group A:	'118				Group B:	'032
		RPM	Temperature	Load	Absolute Pres.		Lambda	Lambda	Bin. Bits	Bin. Bits
	TIME					TIME
MARKER	STAMP	 /min	°C	%	 mbar	STAMP	%	%
	0.01	1720	17	0	1040	0.5	-0.6	-7
	1.1	1440	18	95.3	1080	1.61	-0.6	-7
	2.11	1760	15	95.3	1210	2.71	-0.6	-7
	3.34	2280	15	95.3	1500	3.95	-0.6	-7
	4.6	2960	13	62	1720	5.14	-0.6	-7
	5.73	3680	12	62.7	1730	6.33	-0.6	-7
	6.94	4400	12	63.9	1740	7.54	-0.6	-7
	8.06	4960	12	65.1	1760	8.67	-0.6	-6.3
	9.33	5600	14	67.8	1760	9.94	-0.6	-6.3
	10.48	6160	15	62.7	1710	11.07	-0.6	-6.3
	11.58	5720	15	0	1270	12.17	-0.6	-7
	12.67	4200	16	0	1070	13.18	-0.6	-7
	13.79	3160	18	0	1050	14.38	-0.6	-7
	15.07	4000	18	0	1050	15.63	-0.6	-7
Big_daddy
Oct 20, 2006
3,930
Brummy
your air mass is abit low. 210bhp x 0.79 = 165.g g/s with the air filter box should get at least that or may be abi higher.
Boost seem fine,
Timming seem fine slighty pulling but decent.
Fueling seem bang on, a tad off
Big_daddy
Oct 20, 2006
3,930
Brummy
Pheeeww, thanks Big lad.
How do u work out the timing and fueling from the logs
Well just been learning them as i went along. Well the timming should not exceed 3 as they are high. (im getting 8 :cry:).
The first of the Lambda columns is actual fueling, the second requested.
