help with fault codes
SeatR
399
Norway, Bergen
my exhaust cracked at the downpipe yesterday and a while after the engine light came on.
Is it because of the exhaust leak or is it another fault?
Address 01: Engine
Control Module Part Number: 06A 906 032 DE
Component and/or Version: 1.8L R4/5VT 0001
Software Coding: 11510
Work Shop Code: WSC 00000
2 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
Readiness: 0000 0000
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
I'd imagine the second fault code is related due to the sensor for this being in the now disconnected partially exhaust (I think).
SeatR
399
Norway, Bergen
i assume its no harm to drive with the fault codes?
P1136 - 35-00 - -
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
check pipes under the inlet manifold for splits.
if running rich then this is what it could be, but the same would happen if exhaust dp cracked.
