help THROTTLE bodie?? i got it on vagcom
danielc16
cupra R dan
May 13, 2008
327
guildford
i got the following codes:
01314- ENGINE CONTROL
79-00 – PLEASE CHECK FAULT CODES
17967 – THROTTLE VALVE CONTROL PART (J338): FAULT IN BASIC SETTINGS
P1559 – 35-00
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
is this becuase the throttle bodie has had it?:confused:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
was your battery fully up to charge?
i have seen t'body alignment errors pop up when the battery was tiring, stuck a jump pack on and it went thru fine.
just a thought, you never know
danielc16
cupra R dan
May 13, 2008
327
guildford
Danielc16,
Of course you DID realign it with something like VAG-COM after cleaning it etc?
(Basic settings Adaption?)
some one else done the tba on the old tb but i got a second hand one with 3 months warrenty for £70 so i need to do a TBA agein but will let you know next week as im buying the full version, im just lost with out my car and i gota drive a shity 206 gti :-o
