help temperature gauge. fahrenheit to celsius
ianyerman
any one know why my temperature gauge (outside and air con) has changed to fahrenheit
Need to change it back to celsius. How?
ianyerman
have tried this but doesnt work!
do you have to have the heater fan on or off keys on or off or anything like that?
Noddi
Air Con Problem
Hi I would like to know how to do this too...tried using the instructions and nothing happens. I'd like to get to the error codes. My climate doesn't blow out ice cold air mean't to get it checked out but time went by and then the LCD display started flashing when ignition first turned on. I eventually had it regassed it didn't cure the lack of cold air but it did cure the flashing lcd panel which I thought was faulty. But, have now found out that it was trying to tell me that I had an error with my aircon. Does it keep the fault codes? If anybody could help I'd much appreciate it.
jim devaney
I have the same preoblem
have you rectified it yet? if so how!
nathan110875
I would like to change it too any other suggestions
Weasle
press the ECO button and AUTO button at the same time on the cotrol pannel thats how you do it on a VW should be the same on SEAT :D
