If you haven't read my other post then just a quick update
Fitted my boost gauge and was getting 10psi
Tried another gauge and was getting same reading
So I asked on here and someone asked for my 3rd and 4th gear readings which are below these were done before fitting the N75 Valve:
3rd Gear
4th Gear
Then looking at the figures someone said it looks like N75 valve and so went out and spent £70 on a nice new one for it to make no difference.
Its not the MAF as a replaced that a few months back
There is no fault codes on vag-com apart from outside temp sensor which I doubt will make the boost low
I have the following mods:
Stage 1 remap
Jetex Filter
007P DV
Cat back exhaust
If anyone can help it would be appreciated i'm loosing my rag with this car now and i just wanna
3rd Gear
4th Gear
Stage 1 remap
Jetex Filter
007P DV
Cat back exhaust
