Help! Remote key won't open or lock car?
DaveysFR
526
Northern Ireland: Limavady
Put new battery in my Mk1 leon key and now it won't lock or open car.
It works fine for starting the car etc but it won't unlock or lock it. Central locking is still working fine when you press the button on the drivers door when inside the car.
I only have one push button key and the other spare key is just a normal key with no buttons.
Any ideas how to fix this or would I need to go do the stealers?
Thanks in advance :)
sockpuppet
837
Have you definitely put the battery in the right way up? If it is the right way up, check that you didn't short the battery out as it is extremely easy to do and once you shorted them out they are useless.
Get a multimeter on the contacts and it should show 3.3 volts, if you shorted the battery then the voltage will be 3v or less.
SWANSWAY CUPRA Dealership
