ive tried vag-com on my car and these are the fault codeds i got has anyone got any ideas on what i should do and how
17705 - pressure drop between turbo and throtte valve (check D.V !)
p1297_35_10__
17072 - ECM power relay load circuit (j271) open
p0688_35_10___internittent
1801 - power supply terminal 30: voltage too low
p1602_35-10 intermittent
readiness: 0000 1000
address 08 says excessive comm errors
address 46
01135 - interior monitoring sensors 36-10_opencircuit intermittent
00943 - heated exterior mirror: driver side (z4) 35-10__intermittent
00912 - windows regulator switch :front left(e40)
27-10___implausible signal - intermittent
00944 - heated exterior mirrior - passenger side (z5) 35-00
i did have the passenger window open a little when i did this so dont know if that was the window fault ive had a new battery fitted before doing this test so could it be the wrong battery and as far as i know it doesnt have heated mirrors my d.v is a forge splitter which i did have set on semi atmospheric but have put it to recurculating know but with my CIA on it doesnt seem any different noise wise do i have the seetings wrong
the car is working ok most of the time doesnt feel as quick but only goes into limp mode somtimes and no ecu lights
p1297_35_10__
address 46
