Help Needed - Warning Light!!!!
Matthew Cooke
Hi Every One
I am new on here and I have signed up because I need some advice about a light that has been on, on my dashboard for a long time now. The light is yellow with a circle with a triangle in it.
The car has been tested to fix the error but they said they couldn’t find any thing and for me to take it back which I haven’t got round to doing yet.
I want to sell the car but I don’t feel I can until I have sorted the light out.
All advice is very much welcome.
epts2008
rule the bends
Mar 19, 2009
281
Chelmsford, Essex
Hi there am sure that the light is to do with EPS (traction control) you will probably have a button somewhere inside marked EPS try pressing it and see if the light goes out
hope this helps
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
that won't fix it... that'll be a sensor failure most likely in the TCS / ESP system (depending on what car)
you need it plugging into decent diagnostics, (vag-com) to determine the reason the light is on (if a light is on, it will have logged a fault)
