After yesterdays events with the car overheating to the point where it couldnt get any hotter and steam started appearing from the engine i left the car sitting over night.
Im just back from having another good look at it in the day light and from what i can tell its fine now!
When starting the engine the temp light comes on and gives the warning noise,then rapidly rises half way and stays there!
I was told it may be the water pump,but the pipe that feeds the water o the radiator is warm and feels like waters making its way through it.
I left the car idling for about 20 mins to see if it would overheat again so that i could try and indicate where the problem was coming from once the steam started,but when it never happened i decided to reverse the car outta the parking space when low and behold i spotted a puddle of water sitting right beneath where the radiator had been!
Im no mechanic by any means but basic knowledge is making me think that perhaps its a radiator fault,or can i still consider the water pump as a problem?
