hey guys i have a problem its on my 2001 mk3 ibiza cupra 20vt. the fuel gauge doesnt work, i plugged my vag com into it and went into instrument and got the gauges to move so im assuning their ok and it came up with a fault code when i tested it which was ....
00771 - Fuel Level Sensor (G)
00771 - Fuel Level Sensor (G): Open / Short Circuit to B+
Possible Symptoms
Fuel reserve displayed value 0 (empty)
Possible Causes
Wiring between Fuel Level Sensor (G) and Instrument Cluster: Open or Short Circuit
Possible Solutions
Check wiring between Fuel Level Sensor (G) and Instrument Cluster
Check Measuring Block Value
has anyone else had this problem by any chance and roughly where do i start looking, i checked the plug on the sender and was ok! and i also checked the plug in the back of the cluster, but if the gauges worked through vagcom im sure their fine. its starting to annoy me now lol help would be much appriciated cheers
oh and i would also like to knw as my temp gauge doesnt work, does the coolant temp sensor normally pack ur gauge up totally thanks guys!
Possible Symptoms
Possible Causes
Possible Solutions
