got these codes from vag com
would you say coil packs?
also what order are the cylinders in as you look at the front of the engine?
cheers
Russ
Address 01 -------------------------------------------------------
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT 0002
Coding: 11510
Shop #: WSC 13623
VSSZZZ1MZ2R003841 SEZ7Z0A1200387
5 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
17658 - Fuel Level too Low
P1250 - 35-00 - -
cheers
Russ
Coding: 11510
Shop #: WSC 13623
5 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0302 - 35-00 - -
P1250 - 35-00 - -
