HELP.... G200 Lateral acceleration sensor
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
I know this has been covered before but no search has helped, the warning light came on ages ago( the warning triangle below the abs light) and goes off periodically vag com lists it as electrical fault in circuit, through searches and posts it seemed the sensor was located on the steering column on the left hand side, well i eventually got a new one and went to fit it today it consists of two separate black box's the top large one says it is the yaw control sensor the smaller one does not say what it is.
I fitted it but the light still comes on :censored: and vag com still says the same.
gutted, could it be that this part is nothing to do with the Lateral acceleration sensor and if so does anyone know where it is.
Any help on this matter would be gratefully appreciated:)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Car going too fast now Phil??
sorry cannot help with this one bud, have you checked on vagcat to see where it says this sensor is or if it was the right ones you changed?
Stu_pot
Fire Starter
Mar 26, 2004
374
Near Blackpool
I had this go on my S3 and as you say, its the smaller of the 2 units fitted to the same bracket. The fault WAS listed in VAG-COM as G200 sensor (with another code for it, cant remember). I simply changed it and the light disappeared, there was no need to clear the fault in VAG-COM.
Sorry I cant be any more help than that but if the sensor you changed was brand new then it points to a wiring fault..
