help!! fitting sub and amp to ibiza
chris060685
Ibiza Cupra
Nov 6, 2005
101
dunstable
its all wired up correctly apart from the earth wire, where is the best place to put the earth? the amp will not work because of this, theres no green light, anyone have any idea??
air121005
1,609
Worcestershire
any bolt will do!
on a previous car, i lfted the rear seats and picked one!
disconnect the battery before connecting the earth as it sounds that you have reconnected it at this point?
chris060685
Ibiza Cupra
Nov 6, 2005
101
dunstable
so you have to disconnect the battery completly before you attach it to anything?
because i didnt disconnect the battery at any stage???
CHR15B
2,567
9
Scotland
I've replied to your other post, if you didn't disconnect the battery and have had wires lying around - you might also want to check your fuse!
air121005
1,609
Worcestershire
i'd always reccommend disconection of the battery when doing anything electrical!
a small power surge could pop an electrical circuit easily!
chris060685
Ibiza Cupra
Nov 6, 2005
101
dunstable
ive tried the amp in my mates car and its working fine, must be a dodgy wire sumwhere??? hes got his earthed in a rear light?????
chris060685
Ibiza Cupra
Nov 6, 2005
101
dunstable
all sorted now, one of my mates had a play with the wires at the back of the head unit, it shud av been connected to another blue wire with no label attached??? i did it to the blue wire that said rem.?? thanks alot for all your help anyway, cheers.
