Done a quick search but couldn't find anything..
My mates Ibiza isn't running right and it is throwing up these 9 faults.
We changed the sparkplugs and it never helped, Here are the codes:
16684 - cylinder 3 misfire detected
p0303 -35-00 --
16717 - knock sensor 2 (g66): signal too high
p0333 - 35-10--- intermittent
16712 - knock sensor1 (g61):signal too high
p0328 - 35-10--- intermittent
17536 - fuel trim:bank 1 (multi): system too lean
p1128 - 35- 00 --
17734 - knock-control: cylinder 2: regulation limit exceeded
p1326 - 35- 10--- intermittent
17736 - knock control: cylinder 4: regulation limit exceeded
p1328 - 35- 10
16685 - cylinder 1 misfire detected
p0301 - 35- 00--
17658 - fuel level too low
p1250 - 35- 00 --
Had the fuel trim too lean on my old car and it was the maf so gonna get one of them, Going to change all 4 coilpacks to get them out the way then see if that helps.
Anyone any ideas?
Cheers, Ross.
p0303 -35-00 --
p1128 - 35- 00 --
p1328 - 35- 10
p0301 - 35- 00--
p1250 - 35- 00 --
Anyone any ideas?
Cheers, Ross.
