help - electrical problems
bloshengland
ok i went over a speed bump my heater fan went off and back on now its not working at all that was 3 weeks ago a week a ago the horn went off but i sorted it but only lasted a day it went off i went to start it up last nite it went mad the relays went mad ( could hear them) and the inside light flicked on and off but it started went to it 2day and flat battery so i got a jump start went to work went to start it after work flat battery again plz help i dont know whats up with it cheers
bloshengland
but would that make the heater fans not work at all ? cos the car was starting ok after the fans went off but the past 2 days i have had to jump it got the horn working now wire had fell off
Enemyvirus
I had exactly the same issue ( windscreen wipers would turn off when going round a roundabaout, relays would go off, indicators would stop and start again)with mine took ages to get it sorted but was a pretty basic issue when discovered. You will find that one of your earth terminals has come loose. It will need to be secured back down again. The contacts will need to be cleaned and secured properly.
Hope this helps.
EV
claggan
I have a similar problem and have replaced all wiper parts with no success. Can anyone tell me where to locate the loose earth terminal ???
