Help electric windows not working!
mattbolt
97
Plymouth
Connected up my new guages this evening to the light switch for headlights as everyones suggests. My windows have now packed up. both sides. Checked all fuses and power going to them and have had the negative termianl off the battery for half an hour
any suggestions as my window is now left down!
Deleted member 12147
I had the exact same happen to me, ended up being a fuse. I checked every fuse but none of them had blown. I took it to a local auto electricians who sorted it for me for free. The fuse they replaced was just above the main fusebox under the steering wheel, literally sitting ontop of the main fuseboard. It's a 15amp fuse. I didn't recall seeing it when i first checked the fuses so i'm not 100% sure if they relocated the fuse to this position.
mattbolt
97
Plymouth
my god mate you are my savior!!!!!!!! thanks so much!!!!!!
i must have nocked it out when i was working on the car!!!!!! had so many fuses laying around!!!!
