HELP; Cruise control.....
ballachrishan
Hi Everyone,
My 05 FR TDi has original equipment cruise control on the stalk but it has stopped working?
Has anyone else had the same problem? If so, is it a known fault and easy fix or should I take it to my local Seat dealer?
Many thanks in advance, any information would be most welcome :D
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
VAG-com will help to find out what the problem is.
On my car it was the clutch pedal switch. Others have had the brake pedal switch fail. Unusual behaviour from the brake lights would indicate the latter.
ballachrishan
cruise control
Hi,
Thanks for your quick response and information, I will investigate.
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
If the brake lights are working , my money would be on the clutch pedal
As said , VAG COM will let you know
Sarah
ballachrishan
Hi,
No, its not working at all, I cant even set a speed?
ballachrishan
Thanks, I will check the clutch and brake switch first, this will save time. :D
