arhhh.. losing my rag with it. I cannot seem to get even close to removing my airbag. It just doesn't feel like (as you can't see anything) the instructions:
The instructions are also very confusing, they say push the tab in the direction of the arrow, but in the diagram its suggesting to me that the screwdriver be pushed in that direction which would push the tab in the opposite direction! Also, from the diagram it suggests pushing the spring not the tab!
Anyone got any tips?
Here's the text:
Disconnect the battery earth strap
‒ Unlock the steering column
‒ Rotate the steering wheel -1- in such a way that the spoke is vertical. Remove the entire steering column and push it so that it is in the upper position
‒ Secure the steering column
‒ Insert an angled screwdriver of about 175 mm length through the small opening of the rear part of steering wheel (insert it some 45 mm)
‒ Holding tool T10027 may also be used
Push the tab in the direction of the -arrow-. Upon doing so, clip -10- is pushed backwards, which causes the hook spring -3- on the airbag unit to unlock
‒ Turn the steering wheel 180° in the opposite direction and unlock the other hook on the opposite side
‒ Place the steering wheel -1-in its central position (wheels straight)
‒ Disconnect the connector from the airbag unit
Here's the text:
