Helix SEAT Chelmsford...
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i went in there yesterday for them to investigate a creaking noise i have from the front passenger side of my car...
they were extremely helpful to me... we went out for a test drive and the mechanic (think he was romanian) identified the problem to be with the passenger suspension.
I have FK coilovers fitted by the way!
despite this fact they took it in and spent about 20mins looking at it and came to the conclusion that either the top mount or bottom of the coilover needed a bit of lubication.
as a result i contacted BBT and went their this morning and chris agreed it needed lubing up! ;)
so im goin back there at 5pm today and they are taking it fully apart to clean it up and then reasemble it with lots of lube! :)
hopefully this wil sort the noise out! (fingers crossed! :))
so THANKS Helix SEAT for ur kind help! :yes:
james :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
im phoning them back in a bit!
also have to phone jabba back wen mike is finished mapping
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Good luck!
Did helix seem mod freindly when you were speaking to them?
If you have any problems give cheshunt a call as they have turned there act around and are more than happy to help now
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
thanks... helix seamed very friendly and willing to try but not on obvious things that would blatantly not be covered under warranty!
how it go at the docs scott?
u gonna be on msn... sort of wanted to pick ur brain agin before i go back to BBT! ;)
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Ha ha lets just say im a sick sick man. . . . . . . .. Chatted up a sick girl next to me!
No im back at work at the mo as they wanted to sign me off (too much work on and all that cr4p)
GAmbrose
303
Essex
Whom incidently are very good, but I asked them to look at the Engine coolant temperature sensor that keeps going off and when I came to pick it up they told me "The beeping noise you wanted us to investigate is because your windscreen washer was low"
I'm not stupid, I know THAT. But in Winter my temperature sensor was always going off, yet the coolant level was fine. Still, they had serviced it by then and I wanted to get back before the traffic got too bad so I didn't bother to explain it.
Gary A
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Helix in chelmsford is also a citreon dealer, however they have a sEAT department which only does servicing etc! :)
leegt5
232
Glad they were good for you. Ive got mine booked in for a service on Tuesday and to investigate boost/vacumn leak !!
leegt5
232
Good service as in they did the service in the time they said they would and put in my chosen oil, though when asked if they checked for boost leak guy on desk mumbled so I doubt they even looked as if it was reved you'd hear it and investigate it while on ramp !!
