Hekp Needed!
evokid
87
Just found a severed wire (2 in loom) with no idea where it goes to? Any help appreciated....
It seems to run from drivers side accross front cross member above radiator, has a connector no 1j0973802 which atatches via clip roughly in middle of the cross member behind bonnet release mechanism and has the 2 wires coming from this connector ( both brown 1 with red stripe) which have been cut/severed about 7" from connector with no obvious sign of where they go?
Its a 2001 seat leon 20VT.
Thanks in advance....:help:
evokid
87
BUMP! Ok since found out, it looks like the loom going to Heated Washer jets if im reading ETKA right? It runs along the slam panel, and i cannot see where it should end up?
Not even sure if i have headlamp washer jets!!! Dont remember seeing any from memory?
Any help? Looks like it should have had 2 flat connectors on the end!
Thanks.:(
evokid
87
Hi, the wires are usual size 20 AWG. I guess would end up in fuse box eventually but it disconnect under slam panel beneath bonnet release. I gather its the washer syatem from p/no on connector, and ETKA.
But i cannot see anywhere theyd connect to at quick glance.. Will try to post pic when get internet at home sorted....:lol:
Witalik
ROTTERDAM FEYENOORD
Dec 28, 2008
324
Netherlands
20 awg is quite thick right ? the kind u can use for an amplifier ?
i had also some wire quite that size going to the car and fuse box they where heating for the washer jets of the wind screen...
