heko wind deflectors fitted, but wtf
antzedwardz
61
Cambridge
just fitted my heko wind deflectors and went to close my window and it came back down :| never happened before they where on!! i can get the window up but i have to hold the button down!!
anyone else have this problem??
damon6uk
1.2 nahh cupra
Oct 15, 2010
1,258
Kingston upon hull E.Yorkshire
I sometimes have this problem but this is how I seem to fix it don't know if it's the right way but
find a way so it doesn't come back down and once it's stoped
hold the switch up for about to seconds and whilst holding it take the key out the ignition
And from the on that stoped it for me.
But as I say I dint think it's the right way but it works ;)
I know some people suffer from this as well so they might have another way ;)
Good luck
jamie8954
Diesel FTMFW
Jun 29, 2008
553
UK
it will of been gettin caught , ie once you put your hand on the window when its going up it will go back down to avoid you trapping your hand check for it catchin then just do as above and it will sort itself out
Jordanwaterhous
Motorsport > Scene
Sep 15, 2009
1,936
Leeds
www.facebook.com
Did this for me too, just means the wind deflector is too far in the window canal.
i would hold onto top of wind deflector (whilst on car) and pull towards me slightly (away from car) this should pull it out of the way of the window.
Hope this helps
170gone
170gone
Sep 27, 2010
62
hey
Mines do this aswell...The deflectors are a tight fit, so if its catching you might want to pull gently on the end, down at the bottom to open it up a little. That should help. Peace.[B)]
ballyg
73
Lisburn
I just fitted heko's myself at the weekend and i had the same problem. the passenger side one actually cracked at the bottom. is the bottom of the wind deflector behind the rubber seal on the window?? thats what was wrong with mine. once i got it out it works fine.
