height?
gazjones
i belive they are all the same height. look in the tech spec in the brochure that will say the height of the car
ibizasport16v
217
Clydebank
i stand corrected the sport and the referenceand even the cupra model are the same height...took me forever to find it tho
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
you are right all ibizas are the same height 1441mm but as rim size goes from the refrece with 14" wheels to the cupra with 17" the cupra suspension would be lower and stiffer so the cupra suspension in theory should be 1-2 inchs lower and stiffer
BlackFR
1,724
Not too far away
You sure about that?
The 14" wheels will be running a much higher profile tyre than the 17"
195/55R15
205/40R17
Gives a virtually identical radius...
Ol' Timer
873
Norfolk
I think the suspension on the Cupra is slightly lower than the others. This is from the SEAT media release when it was introduced:
"The Ibiza Cupra also has a lower ground clearance than the FR versions. The front shaft has been lowered by four millimetres and the rear by thirteen, placing them at the same level and lowering the car's centre of gravity."
