usually the temp flap motor needs unsticking/reseting or fixing
Any idea where this is on an
Ibiza?
For the last month or so the fan's not been working at all, so all I've had has been air forced through due to the car moving forwards and air pressure.
Suddenly on the way home tonight it just went mad, onto max, although its varying the speed in cycles but totally ignoring any input via the controls, apart from putting it into AUTO does kick in the compressor and really cold air.
VAG-COM gives the same error as before when the motor wasn't even running, which looks like the control box has gone, I was wondering if disconnecting the battery could
help it reset itself.
00457 - Control Module for Network (J519)
013 - Check DTC Memory
