Heater on 2019 Leon
Radagast
18
Hoping someone has had this problem in the past and can assist! My 2019 Leon Fr has a problem with the heating - if I put the dial on 20 both passenger and drivers vents blow at what I’d guess is about the right temp, however, if I put it on 21 the drivers side goes red hot, about what I’d expect at full, while the passenger side feels significantly cooler. The WJ King garage I bought it at have it as it’s still in warranty but they are getting no fault codes and can’t replicate the problem whilst stationary. On of their staff took it home and experienced the problem so confirmed it exists, but the engineer still can not find the fault. Is this ringing any bells with anyone?
Cainy1989
78
36
Theres a few things it could be, it could be a blend door motor issue not adjusting the temperature, or it could be a blocked heater matrix, given the age of the car this could be a possibility. There was a way to calibrate the flaps behind the dash using the climate controls, but for the life of me I can't remember exactly what buttons to press, that might be a good point to start with, you might not get a code for a failed blend door motor or a clogged matrix
