cuprafay22
hi all as above i have a 55plate cupra tdi and recently the heater stopped blowing hot air into the car?it has the climate controll and the fan works as normal but no hot air even the engine is up to normal temp,it has had a new water pump and thermostat and is bleed corectly but no luck?has any one ever come across this before? i would like to check the controll valve which i guess is controlled by a servo or the like?any idears where abouts it is or how to get to it? would be very greatfull for any help thanks fay
