Hi guys. I was posting in another thread regarding this however I thought I would start a new one as it wasn't directly related to the origional thread.
I recently had overheating issues which are now solved with the replacement of my thermostat and the housing it locates into.
However I still have an issue getting heat from the heater matrix.
Both pipes leading to and from the matrix are hot in use and I have flushed the unit with a hosepipe which went well.
When I turn the temp dial in the cabin it feels like something is happening and the airflow changes from outside air to the matrix however there is still no heat comming through at all.
The heater worked fine with no problems untill the thermostat packed in around three weeks ago. I am sure there is no air in the system and as I said the temp dial seems to be working.
Any ideas guys?
Where is the control flap for the matrix located? How do I check it?
Thanks for everything
Dan
Any ideas guys?
Dan
