Heater fan
will105
30
Northern Ireland
Hi all , heater fan blows as normal but no air coming out of vents , intermitantly it does for a few seconds , switch to recirculate and it comes back to life , anyone any ideas ,quite a pain with the car all steamed .
dimm
TDI?
In Russia we have a probl. looks like yours on 2.0TDI Leon2008. I hope next week our service-centre will fix it. Keep in touch.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Sounds like the recirc motor is either faulty or out of basic settings and its blocking the air into the car.
dimm
:shrug:How 2 say it in Englisn...
In this Leon was one thing in Climatic broken - it was changed 4 free - garanty.
will105
30
Northern Ireland
Hi thanks for your help , recirculate works fine , but fan worked the next morning for a while then stopped again, working for while today but i was only in the car for a few minutes , confused , maybe a faulty sensor or blockage in the pipework which clears itself for a while , will have take apart glove box and fan area if it reoccurs , not looking forward to that!!!!
Nov 2, 2006
1,241
Annaghmore
bebo.com
Mine has blown three speed control resistor packs already. Need to get it replaced under parts warranty. There is a flap that controls recirc, cold and hot air. Could this be faulty and allowing motor to blow but not get to cabin?
will105
30
Northern Ireland
hi will i have to take glovebox , fan and all to access the flap controling hot and cold air, was looking at your photos , is that oil in your intercooler pipes ? mines the same ,any solutions?
1,241
Annaghmore
bebo.com
Yeah, thats oil, i had oil catch can fitted ,took off to re arrange pipes etc and never got it back on. doesnt cure it fully, but removes a lot of oil vapours from rocker cover to turbo intake.
You eill take a panel below glove box out to get filter, speed control resistor etc, for flaps i dont know where they are located.
will105
30
Northern Ireland
cheers , seems to be working fine at the minute , but a lot of condensation in car ,dont know if its connected , where did you fit the oil catch at , where did you buy , would give it a go
Nov 2, 2006
1,241
Annaghmore
bebo.com
I fitted the catch can to the outlet pipe on top of the rocker cover, recirc the gas back into the TIP inlet that original pipe joined to. located can below battery box for time being, need modifications to move it to a more accessable area.
Fixed my heater fan, light guage wire across the poles of the resistor pack where original thermal cut out sat.
cadman2k
188
My Heater Fan has lately develpoped a small squeak when on a low setting.
Apparently this is a common problem over time and down to the fan bearing.
Couple of posts about removing fan and applying some 3 in 1 oil to it.
Looks like it will just get worse over time, anyone replaced one yet?
Understand the New Heater fan from the dealers are about £230 (Its the model fitted with climate), Just wondering how easty it is to fit a new heater fan. Any quick instruction appreciated.
