Headlights.
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
yes they will fit
yes the wiring will need to be modifyed slightly as the new ones have seperate bulbs for high beam
I'm sure it has bean done before so have a search
good luck [B)]
gazjones
yes there was a not in the accessory book saying cars with single bulb lights need the wiring loom changind to fit a two bulb lamp, and it was dealer only job,
Nath.
Jan 1, 2006
8,619
16
mmmmmmmmmm
OK, I would have thought all of the switched 12v supply's would be present on the old loom, just separate them and connect to the relevant spades on the new lights
then earth each bulb either to the body or the original earth
can't see why you would need to go to the dealers
I would imagine it would be similar to fitting aftermarket Lexus rear clusters to a nova........................anyone can do it
gazjones
well you could do it yourself i think but you know what dealers are like anything thats not straight swap needs there experties :lol:
Rosco906
1,445
Burntisland, Scotland
So basically all i need to do is split an earth from the Full beam and dip beam and same with a power, make sure i get the correct main beam with the correct earth and vice versa.
That sound right?
If so its just the same with my old clio when i put the dual optics on.
will my head light connectors fit the new headlights?
Rosco906
1,445
ibiza 02 how do u mean by the black 1's?
I'l get a better pic tomorrow of front car and let you see,
Can someone with the twin head lights please take a photo for me of the back of the headlights. and pm if u have and i will send u my email address
Ross
Nath.
Jan 1, 2006
8,619
16
That sound right?
yeah that's about it
although the earth is common so you only need to find the hi beam, dipped beam wire
you will only have 3 wires going to your old h4 bulbs (hi beam, dipped beam and earth) as h4 bulbs only have 3 connections
on the new lights the bulbs will have 2 connections each so that is where you need to get the earth wire and splice it and connect to both of the bulbs
BTW, when connecting the new bulbs it doesn't matter wich way round you put the supply wire and the earth, they will still light up
let me know if you need any more help
tommmineh
1.2 POWER
Feb 28, 2005
721
Sheffield/Rotherham
@ ibiza02 - every car has black ones....?
@ rosco - the dual headlamps aren't just available on the facelift. The FR & Cupra's (and maybe sports :confused: ) had them since the introduction of the mk4
gazjones
fr and cupra ones arnt black! they are a titanium graphite colour
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
rosco did u ever get your lights on matey, just want 2 make sure no1 else needed to moddify wiring as I didnt.
Anyway av got a set for sale also
Rosco906
1,445
nah, been to busy the now.
House is up for sale, The miss's mum got married work and **** like that.
Ive got a weekend job also as my mainjob so time is pretty hard the now
aigoro
Hi Rosco,
Did you ever change those lights and if so what did you do with the old ones?
