headlight problem, help
benuk
271
UK
Could be a fuse blown? I think :confused: the fuses are under the panel to the right of the steering wheel..
benuk
271
UK
but the other headlight works? is there a fuse for each?
Not sure, but I doubt it sadly :(
How about the wired connections, is there anything obvious.. a volt meter will tell you if your getting current.
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
There may be a fuse for each light. That way you still have the use of one headlight if the other side blew
