Hey guys. Hoping you can help...
My off side headlight has stopped working. I've recently fitted new headlights but they were both working at one stage, although i'm not sure the O/S light was working properly - i didn't check.
The other day i took the car out for a short drive and noticed the off side headlight wasn't working properly. It was only giving off a tiny bit of light, then it just went completly...
The weird thing is, the high beam lights work, but the dipped and main beams don't work. (The indicators all work...)
I've tested the fuses and it's not a blown fuse. A bad earth connection maybe? The bulb works 'coz i tried it in the N/S headlight...
Any ideas? Thanks.
EDITED TO ADD: Will Vag Com pick up the fault? Thanks.
Any ideas? Thanks.
