Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
How do you manually adjust the headlight angle? I've got motors so can move them up and down but it doesn't give alot of movement. Need to Angle them down as they are too high.
there should be a screw or a bolt next to the headlight on the top of the slam panel to adjust, if your not sure just drive to your local MOT place and they will do it for pennies
does anyone know where the motor is that adjusts the angle from inside, i think my right one has broken cos the switch thing only works the left headlight, will i need to replace the whole headlight to fix it (if this is the case ill not bother)
