hi all
does anyone on here no the correct torque settings for a mk3 ibiza cupra head?
ive stripped the hole engine down for a rebuild, head is getting skimmed at the mo got all the bits just not the torque settings to tighten it back up
if anyone needs to know this in the future you tighten all in the correct sequence to 40nm then do a 90degree turn on all in the same sequence then another 90degree turn in the sequence. the sequence is
