code read the car this weekend and got loads of codes, some being for door locks etc like normal lol as i need to replace the door locks for drivers side and passenger side but other than that im getting LOADS of codes for the O2 sensors and find it hard to believe that they are at fault ive checked fuse 43 and seems fine i have noticed the car goes through fuel pretty quick and want to get this rectified to see if that is the issue, the car is remapped but to my knowledge it still has the O2 sensors and maf sensor still mapped in.. i have posted a full scan below..
N112 MAPPED OUT!
N249 MAPPED OUT!
Address 01: Engine Labels: 06A-906-032-AJQ.clb
Part No: 06A 906 032 T
Component: 1.8L R4/5VT 01 0003
Coding: 05510
Shop #: WSC 33278
VCID: 2F6DA5BDED1D4B327C-515A
8 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
P1118 - 35-00 - Open Circuit
17840 - Secondary Air Injection Solenoid Valve (N112)
P1432 - 35-00 - Open Circuit
17695 - Boost Pressure Control Valve (N249)
P1287 - 35-00 - Open Circuit
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 35-00 - Internal Resistance too High
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-00 - Internal Resistance too High
16524 - Oxygen (Lambda) Sensor B1 S2
P0140 - 35-00 - No Activity
17963 - Charge Pressure
P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-10 - No Activity - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
VCID: 75E157D54FC131E2F6-4B18
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 C
Component: 1M-CLIMATRONIC X0604
Coding: 00041
Shop #: WSC 06441
VCID: 224B5C89AECFF65AE3-2592
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 1G AIRBAG VW5 0004
Coding: 12615
Shop #: WSC 06441
VCID: 356197D50F4171E236-4B00
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance Too High
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 901 D
Component: S5-KOMBIINSTR. VDO V02
Coding: 05404
Shop #: WSC 00001
VCID: 275D4D9DC5ED1372B4-515A
Subsystem 1 - Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0646925
IMMO-IDENTNR: SEZ7Z0Y0646925
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
VCID: 70EF66C130A314CA25-515A
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 8N Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 06441
VCID: 04073A11141B186AF1-4B18
Subsystem 1 - Part No: 1J0959802F
Component: 8N Tõrsteuerger. FS0002F
Subsystem 2 - Part No: 1J0959801G
Component: 8N Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 8N Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 8N Tõrsteuerger. HR0002H
6 Faults Found:
00953 - Interior Light Time limit
25-00 - Unknown Switch Condition
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01332 - Door Control Module; Passenger Side (J387)
49-10 - No Communications - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
01179 - Incorrect Key Programming
35-00 - -
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
End-------------------------(Elapsed Time: 02:46)--------------------------
N112 MAPPED OUT!
N249 MAPPED OUT!
Coding: 05510
Shop #: WSC 33278
8 Faults Found:
Coding: 13404
Shop #: WSC 00000
Coding: 00041
Shop #: WSC 06441
Coding: 12615
Shop #: WSC 06441
1 Fault Found:
Coding: 05404
Shop #: WSC 00001
Coding: 00006
Shop #: WSC 06441
Coding: 04097
Shop #: WSC 06441
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
