Hi All. So trying the link above. The Seat Navigation AS says 6PO.919.866 on it... so Im assuming thats MIB2? Trying to load the maps up and pulled off the Overall file from it.
Will see how it goes.
May be somebody put a mib2 standard card in it. The overall.nds trick needs to be applied if it's really a mib2 standard unit. See the
resource and the link I've given to the overall.nds file that gets you out if trouble, you might have the wrong one on it.
Where I say lost cards etc on that links.
It's that attachment
I had the same
problem when I updated my maps last Sunday, had to use a new 32gb card (which I already had), 2 of my old 32gb cards did not have enough space. I checked them for errors but non found. Probably bad sectors: https://www.stellarinfo.com/blog/repair-sd-card-with-bad-sectors/ The...
www.seatcupra.net
That's the Seat year 1 release which fixes all missing overall.nds files.
If however it is a mib1 standard then it won't work. Leyland above may be right that it's a mib1 standard. Googling the unit will reveal I'm sure. We normally start off with a working system that needs upgrading not one that isn't.
That technique is the Seat one that gave you the 6P
How do I know which unit I have ?
Press the “NAV” Button >
Confirm the “Setup” >
“Version information” selection on the display.
Check the first text line in "Version information".
If the first three digits are 6P0 it's a
mib2 standard (serial number is also on the card)
5F with a mapping card in the slot it's
mib1 standard
If not it's a
mib1 or 2 "
Navi System Plus" (no card in the slot)
If it passed that as 6P it's a mib2 standard so just putting the v1 overall.nds file on it will fix it. That's what I'd do.
