My exhuast seems to be off centre since ive fitted faclift bumpers When i had the original one on it was centre in the cut out.Has anyone had this ,if so whats the best solution.
i used a big jubilee clip Thers a Circular hole in the chassis about 3 inches above the exhaust if u look behind ur bumper! Or u could heat up your exhaust brackets and bend em till its central!!
Did you use the juberlee clip as well as the rear mount or did you just use the clip to pull it accross more,It will go but the rubbers are pretty strong so it might have to be a heat job
