Harness fitting
Gunnie
113
Merseyside
Just been trying to fit a 3 point harness, im just havin difficulty with the two straps to the left and right straps. What do you fix to??
Pics would help:)
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Have you read about potential safety issues in the event of a roll-over with harnesses and no cage:
"there's the whole issue of harnesses without rollover protection. If your car rolls, and the A pillars collapse, you have no where to go - the harnesses keep you stuck in position,so your head and neck end up supporting the weight of the car. Not good. If you're wearing your normal 3 points, you end up pushed over sideways into the passenger seat."
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
The bigger worry is harnesses on stock seats - they're not designed to take the vertical loading that crashing with a harness applies.
I've seen a drivers seat bend in two after a crash, my back doesn't bend like that, so I would get a race seat if you wanted the extra protection.
Gunnie
113
Merseyside
Ok ive decided not to use the harness for the sprints:)
My mate gave me it so just wanted to use it..........
Thanks for the comments:)
DannyC87
Mar 4, 2008
3,459
A good alternative is the CG lock - I use one for trackdays etc and it provides better support whilst still being "safe".
