Czechboy said:
...how do I take the brake drums apart...
A damned sight easier than putting them back together, i'll tell you that for nowt...
@ m0rk - there's actually a little wedge shaped thing in the drum that's supposed to adjust the shoe position so that as the shoes wear, the brakes still work. I say "supposed to" because these were notoriously rubbish on mk1 & mk2 Golfs, etc. which use basically the same drum. If I recall correctly, changing the cable is a "drum off" job anyway, so...
Having backed the rear wheel nuts off, put car in gear and chock front wheels, then jack up rear of car. Support on axle stands - depending on how co-operative everything is being, the car may be up in the air for a while, and besides, you'd never work under a car that was only supported on a jack (would you?). Now remove the rear wheels. Looking at the middle of the drum, you'll see a (usually shiny) metal dome. Pop this off using a flat bladed screwdriver. Having taken this off, you'll see a castellated "thingy" - it's not a nut, it's to stop the nut underneath from rotating - on the stub axle with a split pin to keep things from moving. Remove the split pin and the castellated "thingy" should now just lift off, revealling the nut underneath. Undo the nut (which shouldn't be tight) and, assuming you remembered to let the handbrake off before starting work, the drum should now lift off.
Note from bitter personal experience... Having taken the drums off, it's worth working on one side at a time so you have one side with the brake shoes where they're supposed to be that you can use as a reference. If you're not familiar with the innards of a drum, and particularly the shoe arrangement, it's not entirely obvious where everything goes, and from memory the pictures in Haynes are not particularly helpful. And trying to figure it out when you've got a b*stard behind the eyes having taken both sides apart the night before and gone out on the lash is not funny, is it m0rk?
Whilst you've got the drums in bits to replace the handbrake cable, you might as well replace the shoes and fit new wheel bearings (bearing kit costs approx £6 per side from GS&F or about twice that from Halfrausds). You know it makes sense.
Should all go back together as it came apart. If re-using existing bearings (cheapskate), don't forget to settle the bearings, torque 'em up, chuck a wheel on and check it turns and there isn't excessive pay in the bearing, then whip the wheel back off, replace the castellated "thingy" and lock it all up with a new split pin. Oh, and clean and repack the dust cover with fresh grease.
