heatfan8
Insert witty comment here
Dec 2, 2008
368
Berkshire
I replaced my 110 tdi front discs and pads about 8 months and 8,000 miles ago, and they are now warped.
I dont drive like a twonk and dont stomp on the brakes, or leave my foot on the pedal afetr heavg breaking etc
Has anyone else had this problem?
Do a full bedding in process before being sure there warped.
This could easily be pad pick up therefore no need to change these out just get rid of the pick up by re bedding these in
How do I do a bedding in process? And how do I check that they aren't sticking? The discs are normal disc coloured!
if sticking then one side would run hot without using the brakes to simple to check by touching it after a short drive (carefully!)
the stuck side may have turned blue
if disk face looks mottled then this could be pad pickup and not warped disk, same feeling in side.. judder.
what pads you using?
