Golf Vag-com help!?
beezasport
Sold the car to buy a....
Hello guys please could you help me out with the following. I have scanned a friends Golf GTI and these are the falt codes it showed. The air flow meter is faulty and the coolant temp sensor these are going to be replaced. i've had a search around on the internet for the other 4 codes and can't seem to find much on them. The car smells to be running really rich could tis be related to the codes.
Thanks.
Address 01 -------------------------------------------------------
Controller: 06A 906 018 CG
Component: 1.8L R4/5VT MOTR HS D02
Coding: 04000
Shop #: WSC 00028
6 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
01249 - Fuel Injector for Cylinder 1 (N30)
26-10 - Output Open - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
01251 - Fuel Injector for Cylinder 3 (N32)
01252 - Fuel Injector for Cylinder 4 (N33)
Readiness: N/A
