golf mk4 tdi 130 auto
beezasport
Sold the car to buy a....
I have done a auto scan of my mums car tonight and it came up with these results.
im guessing it needs a new engine temp sensor and a new battery in the key fob but can anyone shed any light on the others please.
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 FG
Component: 1,9l R4 EDC 0400AG 1470
Coding: 00001
Shop #: WSC 01266
WVWZZZ1JZ2W472200 VWZ6Z0A4043503
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 09A 927 750 J A
Component: G5 Getriebe 09A 0141
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 01266
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 926 C
Component: KOMBI+WEGFAHRS. RB8 V12
Coding: 05414
Shop #: WSC 00000
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01266
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1W Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 01266
1 Fault Found:
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 D
Component: Radio BNO 0006
Coding: 03403
Shop #: WSC 01266
End -------------------------------------------------------
Uwe@Ross-Tech
392
www.Ross-Tech.com
Coolant sensor or connections to coolant sensor.
Battery in the fob has nothing to do with the immobilizer / key codes you have. Check connection between pickup coil (at ignition lock) and immobilizer (in instrument cluster).
-Uwe-
Uwe@Ross-Tech
392
www.Ross-Tech.com
Nope, since it's in Address 17 (Instrument Cluster) it has nothing to do with the battery in the fob. The immobilizer transponder in the key is "passive" (powered by induction from the pickup coil).
The battery is for the remotes (which are handled by the locking system).
-Uwe-
