Glovebox Light Leon Mk II....Anyone fitted one
Maximus2000uk
Funnily enough someone mentioned to me how dark the glovebox was and its true! Need a light for it asap too.
Bedlam
868
236
North Yorkshire
Will see what this thread produces
I have bought a pack of 4 LED "Prism" Micro LEDS from Halfrauds in red (can get white, pink or blue too) for £5.
These need only a 6MM hole and include a snaplock holder, have not fired one up yet to see how bright/intense/hot one is, am considering one pointing down to the darkness of the storage behind the gear lever too.
What armrest have you got and how much, I need one too
Bedlam
868
236
North Yorkshire
Fired up the laser red led from Cig Lighter and tried under radio storage, more like a spotlight than a spread of light and not tooooooo bright, in fact pretty much like an SAS assassin laser!
Can't make my mind up yet on whether suitable or whether two might work.
Which "ones" are they Dave and where from?
13snc
13SoNotCool
Jan 8, 2008
62
Croatia
www.seatclubcroatia.com
vw passat light housing
LED bulb
you have to install small button, when is pressed it is of and on when release (open box)
I can't write tutorial.. my friend did it.. but basicly.. you need to pull wire from cigarete lighter, add a small button switch and connect to passat light.. there is a place where that light was suposed to be.. I saw the other day one new leon that has light in glowbox by default..
DJHotspur
Could you not just fit the one from the Cupra?
Mine has one?!
stuartsjg
244
Aberdeen
is there any point putting a light in the glovebox given that you can baerly fit anything in it thats usefull?
I manly use the little under passenger seat store. Ive got in there:
- Satnav + cradle when not in use
- Can of irn-bru for emergancies
- small 12v fan heater
- vagcom cable
- hand/face freshening wipes
As for the glovebox, i can hardly fit in a 3.5mm mp3-aux cable allong side the user manuals!
Stuart
Rampage
Trainee Northener
May 24, 2003
1,035
Can you not just turn on the main cabin light if you need to see whats in there?!
DJHotspur
I will check my VIN number before i leave work and PM when i get home if that helps?! :)
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
I don't have one on my 57 plate cupra.............strange that some cars seem to have them.
Maybe its the K1's that seem to have them????
ianltd
89
Powys
Taken a while to reply, but I thought I had one when I read the thread late Sunday night and I checked today and YEAH I HAVE ONE and on a courtesy switch too:D
Strange how some do and some don't isn't it:confused:
58 Plate Stylance.
Ian
