This is continued from the thread about spares in the general discussion thread.
I went down to the dealer and bought a new sump plug this morning. Then the oil - Fuchs - arrived at midday today. Pretty good I thought, a day and a half from ordering with cheap, free, delivery traveling the length of the country! So by early afternoon I couldn't stall any longer and put my "car doing" clothes on. This is the first time I've laid a spanner on her as the dealer has been looking after her during the warranty period. (She's just coming up on 4 years old)
I've been fretting away about the sump plug. Silly really because the dealer technicians surely know what they're doing? having had to deal with stripped sump plugs in alloy sumps before, and knowing what a phaf it is, I was hoping for the best. Of course there was absolutely no problem, the plug unscrewed beautifully and the new one, after the oil had drained, went back in perfectly and torqued up to 30NM without giving me the slightest reason to worry. The oil filter screws to the front of the engine horizontally and I'd noticed that my new Mahle brand filter did not have an anti bleed down diaphragm (you can see it through the outer holes in the top of the filter if it has one. So I was delighted to find that the genuine VAG filter which I removed didn't have one either. Nice also to be able to prime the new filter before fitting - doubt if the dealer would do that. I also dropped the partial under tray to get better access to the filter but probably don't really need to though. I'll try without next time. I'm glad I went for the 5 litres of Fuchs now rather than the 4 litres of Castrol as 4 litres has taken her to just under the full mark - probably it'll be on full after standing overnight - had I gone with the Castrol I wouldn't have even had enough left to oil a bonnet hinge. I'm glad this engine holds so much oil as I think engines with turbos need a good quantity of oil to cut down on stressing the oil.
While the front was up in the air I thought I'd just clean up the brakes as they obviously hadn't been touched since she rolled off the line. The off side dismantled very nicely - after I clocked that little tab which sticks out the bottom of the caliper and locates behind the bottom carrier guide! 4 years of dust and gunge was quickly cleaned away, pads glaze busted and Cera Tec smeared sparingly about before reassembling. All going so well. N/S top guide pin unscrewed OK but felt just very slightly tight at the half way stage. Bottom guide pin? Oh dear! moved about one turn quite nicely then started to tighten up. Screwed back in and slaistered Plus Gas all over (put some on the pin too - ha ha!) Tried again but it was still a bit tight, came out though. Caliper and pads all cleaned up (pads about half gone) but on reassembly the guide pin started to tighten up almost immediately. Whipped it out and shone a bright light (cree) down the hole. Hmm, still quite a bit of thread especially further in to the hole but not in "perfect" condition. Searched all through my tap and dies box but nothing will fit - Turns out it's a metric 9 by 1.25 thread. I do have a thread file though so got the pin's thread looking lovely again with this then put a little valve grinding paste on the thread and gently, little by little, wound it in and out, in and out of the threaded hole in the hub being carefull to keep it really square on (this car doesn't have a separate caliper carrier unfortunately). After a few minutes of doing this it all started to feel much nicer so I took the slider pin out and cleaned up with some brake cleaner. Carefully reinstalled the caliper and slider pins. Top pin tightened just fine. Bottom pin? It felt a little "ropey" for the first turn and a half or so but then screwed home quite nicely. I used thread locker and my torque wrench on both pins and they both tightened up nicely so I'm confident it's OK for now - I'm not worrying about it anyway. Next time it needs to come off might be a different question though. I've been aware of the slider pin thread repair solutions (thread inserts of various designs) for some time. I think when the good weather returns I'll buy one and "sort" it properly.
With this unexpected "excitement" I ran out of time so tomorrow I'll be doing the air filter, cabin filter, cleaning up the rear brakes and generally running an eye over everything else. Oh, and fitting a headlight bulb to my daughter-in-law's Honda Jazz Mk1 - a fun job which involves partial removal of the wheel arch liner and, if I'm unlucky, loosing some blood!
