Getting boost gauge line through bulkhead?
andieleon
49
Farnborough, orpington
hey, i have a day off work today and want to make the most of it so i am running my gauges in. the only problem i have is finding a hole to take them through into the engine compartment?? does anyone no where the hole is or if i can take it through where the loom goes through ( cantsee no space though)??? helpppp
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Mine was simple just drilled the hole (don't go mad/deep with the drill) and pushed the vacuum hose through enough so i could see it through the fuse box hole (after i removed it)
Simples!
andieleon
49
cheers guys i took it through like in the guide and is now working fine. thanks for the help, nut i do now have another problem??
i noticed that at the beggining of the run when i took it out to test it i was getting a healthy reading of around 0.7 0.75 and everything was ok but when i was on my way back for some reason it was only boosting to 0.5 now i thought i heard this happen the other day through the dv noise but wasnt sure now this has proved that somthing is wrong?? any ideas???
