Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
i had to have mine fixed as i couldnt select 1st or 2nd. guy at geaarbox garage siad 1st an 2bd selecctor prone to failing as there is only 1 rivet hilding it on. what was yiur gearbox fault
i had a problem with it at 1st with 2nd gear! it would HOWL really loud like a transit wen it went passed 2k Revs. they said it was the fly wheel or something and also the sealing came away from the gearbox. which leaked oil onto an into the clutch. under warranty it was repaired an a new clutch was fitted. but it happened again. dealership took it bk in to have yet another look an said it was un-repairable :S they had to replace the whole gearbox which has now been done but now i have a ANNOYING rattling coming from the gearbox which i think is the bearings inside the gearbox??
if u do have a problem, (hope you dont) then you will hear LOUD howling noise like its been electronically tuned to maximum. an it will gradually get louder as times goes on. you wont loose any power but dont drive it! Fingers crossed..
mine crunches almost every time I engage second gear . . . that's if I take 1st gear to over 4000 revs though . . . I need to book it in for SEAT to have a look at it . . . courtesy car for a week . . . hope I get a cupra
blimey i hope mine doesn't need that as its only done 13700 :| Shall have to keep an ear out! I think when the warranty runs out i'm going to stick it into SEAT just before and get them to check it over completely!
