My 05 plate Leon FR TDi has an intermittent issue somewhere with the gearbox/clutch and I am wondering if anyone else has had similar problems... This has been ongoing for the past 3 months...the car has done 53k miles.
Occasionally when you dip the clutch the gearbox will crunch going into 1st or second. Obviously 1st at a standstill then second at around 10mph. The pedal is definately all the way to the floor. Once past second it seems fine. This only happens occasionally (around once a week/200miles but more in town driving as more use of the clutch). I am not loosing any fluid. Also sometimes if you come to a standstill in gear and dip the clutch it wont let you take it out of gear without a sharp tug.
This all says to me that the input shaft of the box is being dragged around by the clutch as its not fully disengaging. But it doesnt happen all the time and not losing fluid tends to say to me I dont have a dodgy master or slave cylinder.
Also I have started to notice it sounds like the diff is whining, you can hear it sometimes and not others, but it doesnt seem to matter what gear its in. That said I dont know if its something I have started noticing because of the other problems, or not...
Any ideas?
Cheers,
David
Any ideas?
Cheers,
David
